in Search
Scroll bars and text
Last post 07-02-2009, 12:45 PM by wgrandon. 2 replies.
Sort Posts: Previous Next
  •  07-02-2009, 11:41 AM 5318
    I have to create a mock up of a "Terms of Use" but there is a LOT of text. How can I put the text in a set area that scrolls? Also, the site I'm working on uses a custom scroll bar. Is there a way to use the images for the scroll bar that's on the site in the prototype?
    Thank you,
    William
    Filed under:
  •  07-02-2009, 12:40 PM 5319 in reply to 5318
    Re: Scroll bars and text
    Hi William,
    There a few options for the scrollbars.
    1. The text area widget has scrollbars, but the text within it is not rich text.
    2. (Preferred) Put the text in the first state of a dynamic panel. Then right-click on the dynamic panel and use Edit Dynamic Panel->Show Scrollbars As Needed.
    3. Put the text on a separate page and use an inline frame widget that loads that page.
    There isn't a way to use your own images on those scrollbars though.
    If you do want to create your own scrollbar, you could use the images and then create discrete "hot spots" (image map regions) on the bar that can be clicked on to move the scrollbar using dynamic panels and the move panel action. You would need to manage the scrolling text too which I think could also be done using dynamic panels and the move panel action. But there isn't a simple way to implement the dragging of the scrollbar.
  •  07-02-2009, 12:45 PM 5320 in reply to 5319
    Ok, I'll do what I can and see what happens. Appreciate the info.
    Thank you,
    William
View as RSS news feed in XML
