in Search
Popup Message Box
Last post 07-02-2009, 2:10 PM by victor. 3 replies.
Sort Posts: Previous Next
  •  07-02-2009, 11:39 AM 5317
    Popup Message Box
    I need to create a popup message box that displays when an option is not checked. I am uncertain how to use the popup window function in Axure. Is there an easy way to do this? Should I use dynamic panels? Or do I need to create a separate page that then links to the option conditions? If you need clarification please ask. This is hard to explain without screenshots. Thanks in advance.
    Justin
    Filed under: ,
  •  07-02-2009, 12:51 PM 5322 in reply to 5317
    Re: Popup Message Box
    Hi Justin,
    If you want the message to show up in a separate window you could use the Open Link in Popup Window action, or if you want the message to appear on the page, you could use dynamic panels. Here's is how it might look on the interaction of the checkbox:
    OnClick
         Case 1
              Open MyMessagePage in Popup Window
    or
    OnClick
         Case 1
              Show MyMessagePanel
    If you use the dynamic panel, you'll also want to set it to be hidden by default. Are you familiar with dynamic panels yet? If not, this can help http://www.axure.com/p201_1.aspx.
    There is still the condition piece though. I think the condition might look like:
    OnClick
         Case 1 (If is checked of MyCheckBox equals false)
              Show MyMessagePanel
         Case 2 (Else If true)
              Hide MyMessagePanel
    More on conditions here http://www.axure.com/p202_1.aspx.
  •  07-02-2009, 1:54 PM 5324 in reply to 5322
    Victor,
    Thanks for the reply. I ended up using a dynamic panel and got it to mimic the actual function pretty well. Because I needed a message box similar to what displays in Windows when there is an error I'm assuming I have to use dynamic panels for this. Is the Popup Window function in Axure only for displaying new popup browser windows? Thanks.
    Justin
  •  07-02-2009, 2:10 PM 5327 in reply to 5324
    Hi Justin,
    That's great. Yes, the popup window is meant for opening a page in a new browser window.
View as RSS news feed in XML
